            The BT Baby Monitor 150 is not only a hit with many thousands of parents, it's also won a number of awards for its combination of crystal clear sound, reliability, features and value for money.
Mumsnet Best Award 2011
Winner - Best Baby Monitor - Mother & Baby magazine 08/09
Best Buy - Baby Monitor - Which Magazine Sept 08
Reasons to have BT Baby Monitor:
The BT Baby Monitor 150 provides advanced features such as Mp3 plug-in and
integrated thermometer, DECT digital technology, polyphonic lullabies,
rechargeable batteries and a torch on the parent handset - High definition
sound gives you a new level of sound quality - so real it sounds like your
baby is in the room with you, MP3/CD audio source* lets you play your baby's
favourite music at bedtime to help them sleep. With a sleek stylish design,
not just practical and packed with features for your peace of mind, but with
its sophisticated clean lines and styling it looks great in any room and
you'll be eager to show it off - Furthermore the Vibrate function gives you
peace of mind without the disturbance of standard baby monitors.
*Please note a separate audio device (such as an mp3 or cd player) is required
- Digital DECT technology with Hi-Def sound
- Rubber key zones on both units
- Mains or battery powered
- Rechargeable batteries in parent unit
- Portable parent unit
- Interchangeable power adapters (X2)
- sound level indicator LED array
- parent talk back
- Mute function on parent unit
- Vibrating alert on parent unit
- Auxiliary input for external audio sources
- parent voice recording on baby unit
- Torch on parent unit
- Room temperature monitor
- Backlit b/w dot matrix LCD screen
- Timer/alerts on parent unit
- Nightlight with adjustable brightness
- Illuminated key zone on baby unit
- Multiple Polyphonic lullabies
- Fully adjustable volume and sensitivity
- Range up to 300m outdoors & 50m indoors(+)
- Travel bag
- Belt clip
- Out-of-Range warning
- battery low indicator
