The BT 5960 Cordless Phone makes staying in touch at home easier, with no wires and ease of use, it's the perfect family phone.
Basic call blocking features prevent nuisance calls from interrupting your day, and a large wireless range means you can walk around the house without the phone signal dropping out.
There's also a loudspeaker, and ringer with adjustable volume, and a screen with caller ID, so you can see who's calling before you pick up. The clock has an alarm function, which makes the BT 5960 perfect for use as a bedside phone.
- Quad Handset Pack
- Digital cordless telephone with answering machine
- Blocks up to 50 numbers
- Hands-free speaker
- Easy set up
- Do not disturb mode
- Up to 60 minutes answer machine recording time
- Save up to 100 contacts
- Up to 12 hours talk and 120 hours standby time
- Greater call control with options to block calls by specific numbers *
- Blue Backlit screen
- Batteries Requried: 2 x AAA NiMH
- Dimensions: D 5.5 x W 11.0 x H 17.0 cm
- Colour: Silver
*You'll need a Caller Display service from your network provider to block nuisance calls and for text messaging features. Charges may apply.
