Digital cordless phone with answer machine
Portable – Take your handset away from the base unit for the most freedom while chatting. (Up to 50m indoors and 300m outdoors).
Greater call control - With options to block calls by specific numbers or certain call types.
Easy to set up – Setting up this phone is easy with it’s simple to use menu and 1.6" backlit screen.
Key features
- Blocks up to 50 numbers
- Do not disturb mode
- Up to 20 minutes answer machine recording time
- Save up to 50 contacts
- Up to 10 hours talk and 200 hours standby time
- Greater call control with options to block calls by specific numbers or certain call types*
*To block nuisance calls or use text messaging, you need Caller Display from your network provider. Charges may apply.
