BT 2700 Cordless DECT Phone with Nuisance Call Blocker
Key Features
- Avoid nuisance and unwanted calls with our new BT 2700*
- Block up to 50 specific numbers or use Do Not Disturb to silence your calls
- Get the most our of your phone straight away with our easy to use menu and great sound
- BT 2700 is available in single, twin, trio or quad handset pack sizes
Detailed Features
- Built in Digital Answer Machine
- Block up to 50 numbers*
- Excellent sounds quality
- Easy set up
- Handsfree speaker
- Long range reception, up to 300m outdoors, 50m indoors
- Up to 12 hours of talking, 120 hours on standby
- See and hear if you have a second call waiting
- Easy to read screen shows when you have messages
- Do Not Disturb mode
- Save up to 50 contacts
- Backlit screen
- Redial any of the last 10 calls you made
- 1.6 inch backlit screen
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
