Works with any Broadband provider
BT's 11ac Dual-Band Wi-Fi Dongle 900 has been designed to work with any service provider to make sure everyone can make the most of their broadband around their home.
What does BT’s 11ac Wi-Fi Dongle 900 give you?
Upgrade your computer of laptop to Dual-Band Wi-Fi to enjoy greater speed and reliability.
Easy set-up – get Dual-Band Wi-Fi on your device in minutes.
Everyone loves to be online and with BT’s 11ac Dual-Band Wi-Fi Dongle 900 you can connect any laptop or computer wherever, whenever and however you like. With more 11ac dual-band routers around, you can now upgrade your devices to take advantage of the improved reliability and speed of 11ac dual-band wi-fi. Just plug the 11ac Dual-Band Wi-Fi Dongle 900 into a USB port, follow the easy-to-use set-up guide and you’re making the most of your 11ac Wi-Fi in minutes.
Simple to use
The 11ac Dual-Band Wi-Fi Dongle 900 from BT is easy to use. Simply plug into a USB socket of your laptop or computer, follow the easy to use set-up guide and enjoy a great 11ac Wi-Fi experience in minutes.
Want Dual-Band reliability and speed?
Get a faster Wi-Fi network by upgrading your computer to 11ac Dual-Band Wi-Fi.
Make the most of your Broadband
BT's Dual-Band Wi-Fi Dongle 900 enables you to make the most of your Broadband by upgrading your laptop or computer to 11ac Dual-Band Wi-Fi technology.
The BT connectivity range
BT's 11ac Dual-Band Wi-Fi Dongle 900 is just one part of BT's new connectivity range, which has been designed to solve all connectivity issues to ensure everyone makes the most of their broadband around their home. Other products include Broadband Extenders, Dual-Band upgrade kits, Wi-Fi Extenders and switches, ensuring all your major connectivity requirements are covered.
