Labels often have to incorporate a considerable amount of important information, so you need a printer that can put it all together efficiently and with consistently high-quality results.
The TD-4000 prints at up to 110mm per second and 300dpi, with a built-in automatic cutter. Your labels can be up to 102mm wide, and anywhere from 25mm to 3m long.
The TD-4000's P-Touch Editor software supports barcode printing, and also allows you to import graphics and date for a truly personalised solution – so this feature-packed professional label printer always delivers.
