Being able to print your own cable labels on demand makes everyone's job easier, demonstrates a committed approach to safety and enables on-going maintenance to go smoother. And the PT-7600VP allows you to achieve all this and more.
This durable label printer (carry case included) helps you indicate all kinds of components clearly and quickly up to 24mm label widths. And with over 35 common electrical and audio/visual symbols pre-loaded, it makes effective labelling a simple job – you can even tag labels with your own company logo for a professional finish.
Easy to use, efficient and economic, the PT-7600VP has professional labelling all in hand.
