Get the job finished immediately by printing on the go with the PJ-662.
Easily carry this compact printer with you to meetings and appointments or keep it mounted in your vehicle – whichever's better suited to your line of work. You can also take your pick from a range of software features and accessories for a fully tailored print solution.
Connect via Bluetooth, IrDA or USB wherever you are. Plus the PJ-662's thermal printing system mean you're guaranteed great results no matter the conditions.
