The PT-9600 allows you to label in more ways than ever, so it's the ideal machine to have by your side is you want to keep everything perfectly ordered and organised.
Whether you use it with your PC or Mac or as a standalone electronic label printer, the PT-9600 delivers sharp, clear results – even when you're dealing with bar codes and serial numbers – and you can include a wide range of common industry symbols on your labels too.
This hardworking machine also lets you download label designs and transfer images and graphics. The notebook-style portability makes it simple to apply crack and peel labels, while the backlit display also makes previewing and editing easy.
No job's too big or too small for the versatile label printer, which produce high quality, durable labels that always stay put.
