| Quicklinx: | 9NJQWS00 |
| Mfr#: | MFCL2740DWZU1 |
The MFC-L2740DW is a fast, professional, network-ready mono laser printer, scanner, copier and fax perfect for the Small or Home Office.
With cloud connectivity, and compatible with a number of mobile printing apps, this professional All-in-One matches the ambitions of even the most technologically savvy Small Office. Also offering Wi-Fi and Wired Network connectivity you can print from anywhere and using a number of devices.
The 6.8cm colour touchscreen makes menu navigation simple, while print speeds of up to 30ppm mean there's no waiting around once you've pressed print. Also expect quick and easy printing and scanning from anywhere using the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint or Wi-Fi Direct, as well as scan and print capability to and from cloud services such as Dropbox, evernote and onedrive.
Boasting a 250 sheet paper tray and 35 sheet Automatic Document Feeder look forward to more time between refills and set jobs to print while you carry on with the tasks that matter. As well as saving time, save money with the standard 1200 page inbox toner, with optional cost-effective, high-yield toner cartridges available. Double-sided printing, copying, scanning and faxing also helps to reduce unnecessary waste.
