Compact and connected the MFC-L2720DW offers mono print, fax, copy and scan direct to the cloud. Wi-Fi and Wired Network connectivity ensures that all your Small Office print, scan, copy and fax needs can be met with the simplest of steps and least hassle.
Including a 6.8cm colour touchscreen for easy menu navigation and with print speeds of up to 30ppm, this mono laser is perfect for quick printing and variable workloads. The 250 sheet paper tray and 35 sheet Automatic Document Feeder mean that you can keep working on the things that matter, while even the biggest printing jobs take care of themselves.
This is a truly connected device, allowing users to print and scan from anywhere using the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint and Wi-Fi Direct, as well as scan and print capability to and from cloud services such as Dropbox, evernote and onedrive.
With the 1200 page inbox toner, double-sided printing as standard and cost-effective, high-yield toner cartridges available, you can simultaneously reduce unnecessary waste and make genuine long-term cost savings too.
