Our best A3 inkjet yet
The MFC-J6920DW can help your team to work faster, smarter and more collaboratively.
Connect direct to the cloud and your mobile or tablet for faster results, plus near field communication means you can print instantly by simply holding your device up to the sensor.
With double-sided printing and XL ink cartridges that offer you better value, the MFC-J6920DW cannot only streamline your working processes, but your on-going print costs as well.
Scan, copy fax and print all in one, and take advantage of a range of intelligent features to print professional A3 documents that do your hard work justice.
Key Features
- Print, copy, scan and fax - all up to A3.
- Up to 22ipm mono / 20ipm colour print speeds
- Automatic 2-sided print, copy and scan
- Wired & wireless network ready + mobile/cloud compatible + NFC
- 6.8cm colour touchscreen
- Up to 500 sheet paper capacity
