            The Brother HL-L5000D monochrome laser printer is ideal for small offices that need a printer with a Parallel interface for wide application compatibility. It features reliable, fast printing up to 42 ppm and cost-efficient output thanks to a high-yield replacement toner cartridge. Plus, automatic two-sided printing helps save paper. Built-in parallel and USB interfaces provide flexible local connectivity and PCL6 and BR-Script3 emulations enable comprehensive application compatibility. Use the 250-sheet capacity paper tray for letter or legal-size documents, and print on envelopes and alternative media types from the 50-sheet capacity multi-purpose tray. For fewer refills, you can expand the paper capacity to 1,340 sheets with optional add-on trays.
