Built with performance in mind, the efficient and speedy HL-3170CDW makes it simple to create standout, professional-looking documents.
This flexible colour printer is ideal for small but busy spaces. Optional high-yield colour toner cartridges, double-sided functionality and low energy consumption can help to reduce your total print costs, while the fast print speeds (22ppm) and easy-to-operate backlit LCD screen control guarantee quick and impressive results.
To make it easy to stay connected wherever you are in the office, the compact HL-3170CDW features both wired and wireless technology. Plus you can also send documents to print direct from your mobile device.
