A perfect Mono Laser printer for connected Small Offices. Print high-quality documents in black and white with the touch of a button with this tablet and Wi-Fi enabled, mobile print compatible machine.
With print speeds of up to 26ppm your documents can be ready before you arrive at the printer to pick them up. The 250 sheet paper tray allows you to spend more time creating your documents instead of reloading an empty paper tray to print them.
Also prepare to print from anywhere, using the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint and Wi-Fi Direct you can send your documents to print using your tablet or mobile device.
With efficiency in mind, the double-sided printing feature and optional, high-yield toner cartridges you can expect reduced waste and costs.
