The powerful HL-4150CDN is packed with features that make office life easier.
Print speeds of 24ppm and the ability to print direct from a USB drive saves you time, while automatic double-sided printing can keep paper costs down. Plus the low power consumption could make a noticeable difference to your energy bills.
Protect your most confidential documents with data encryption and Brother's Secure Print feature – just activate the HL-4150CDN using your personal PIN code when you're ready to print.
And the expandable multipurpose tray means this stylish and reliable printer is prepared for any job.
