Small office? You've just found your perfect printer. The HL-2130 may be small in size but it's big on efficiency with a fast 20 pages per minute print speed (the first in less than 10 seconds) to make sure you're not kept waiting. The impressive 250-sheet paper capacity saves you time too, with less need for refilling. It keeps costs down with separate drum and toner, Energy Star approved technology and also includes 12 month warranty with lifetime technical support.
You'll appreciate being able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out after only 10 seconds. Sharp, crisp text and accurate reproduction of fine detail are a given too, with the HL-2130's high print resolution for outstanding results.
With the HL-2130 high performance doesn't mean high costs. Save paper and use less toner by reducing 2, 4, 9, 16 or 25 pages onto just one A4 sheet with N-in-1 printing. Using the toner save mode can further reduce your running costs.
