PowerCart 16 promotes a robust all steel construction alongside an energy saving timer module that prevents energy wastage as well as protecting your building circuits.
The built-in power management system not only protects your laptops and prevents your building's circuits from being tripped, but it also features an energy-saving timer unit with 2 programmable timer options, which can be set to start charging over 2 separate time periods in one 24 hour cycle. The timer can also be set to charge your laptops during the evening or weekend to take advantage of off-peak energy supply hours, helping to reduce your electricity bills.
Simultaneous data transfer
Updating a full set of laptops with the PowerCart 16 is simple. Featuring a built-in 19" rack for mounting a network switch, as well as an optional fan and network kit upgrade, which enables all laptops to be connected to the LAN and simultaneously updated even whilst charging.
Easy to use, neat and tidy
PowerCart is quick and easy to set up with power pack shelves in the rear of the cart along with reduced length 2-pin and 3-pin power adaptor leads, which dispense with the laptop's own 3-pin plug and lead, reducing the amount of excess cable and eliminates cable clutter.
Low maintenance
All the electronics are housed in an easily removable timer module.
Robust all-steel construction
The robust all-steel construction provides a significant theft deterrent, while the separate lockable ICT technician door offers secure access to the power module to prevent unauthorized tampering.
Bretford PowerCart L16H cart - for 16 notebooks
Cart
102 cm x 55 cm x 98 cm
Recommended Use
16 notebooks
Material
Steel
12 years warranty
102 cm
55 cm
98 cm
Material
Steel
AV Furniture
Cart
Recommended Use
16 notebooks
Cable Management
Integrated cable management
Locking casters, lockable, Electric Power Management (EPM)
Limited warranty - 12 years , Limited warranty - power system - 2 years
