Reliable: The Smart Home Water Alarm alerts you at an early stage and prevents damage.
Make your home more secure. The smart Water Alarm informs you in the event of a water leakage - visually, acoustically and via app - and thus reliably prevents significant material damage.
Reliable alarm
The smart Water Leak Detector alerts you at home in the event of a water leakage acoustically by means of beeping and visually by means of the blue flashing of your Philips Hue lights
Notification via app
The Smart Home Water Alarm also informs you when you are out via push notification and live image. See what is happening at home and make an emergency call directly via the app.
Immediate damage limitation
In emergencies, use an automation to deactivate devices connected to plugs in a flash. In this way, you can immediately protect your house from major water damage.
Damage limitation thanks to intelligent networking
In the event of a water leakage, the Water Alarm deactivates devices connected via plugs. You thus avoid major hazards due to water damage on electrical devices.
