Our smart wireless Smoke Alarm sounds the alarm – in case of fire or uninvited guests
The connected Smoke Alarm from Bosch Smart Home alerts you to the presence of smoke in your home. Additionally, it sounds a loud alarm if other components of the Smart Home System report noticeable events. So the Smoke Alarm protects your home twice over: both from fires and from undesired intruders.
Alarm on site andvia app
Smoke is developing in the living room but you are not at home? The connected Smoke Alarm not only provides an alert by means of the siren on site, but also via the app. Thus, you can respond immediately even when you are out and can activate an emergency call.
Part of the alarm system
The alarm siren of the smart Smoke Alarm is additionally used when connected Motion Detectors or Door/Window Contacts register unusual movements. Thus, as part of the alarm system, the smart Smoke Alarm also provides protection from undesired guests.
Alarm signal throughout the house
The alarm forwarding provides for even more security. If the Smoke Detector sounds on the top floor, it transmits this alarm to all the connected Bosch Smart Home Smoke Alarms and Twinguards throughout the house. This protects property and life.
Easy installation and minimal maintenance
Installing your Smoke Alarm via the app takes only a few minutes. Thanks to a battery lifespan of 10 years, the maintenance workload is also kept to a minimum.
For fast action in an emergency
Thanks to the link to the Bosch Smart Home App, you see immediately in which room your connected smart Smoke Detector is sounding. This allows you to act in a targeted manner in an emergency.
Emergency call with just one click
In the event of an alarm, a quick response is crucial. Thanks to the emergency call button that appears on the alarm screen, you can request help immediately using the app.
