Bosch Smart Home Motion Detector keeps an eye on the inside of your home. Use it as part of the alarm system when you leave the house. It detects movements reliably and precisely, instantly sounds an alarm and warns you immediately via app if unwanted guests try to gain access to your living spaces. When you are at home, use your smart Motion Detector for automatic lighting control.
Smart motion detection
The Motion Detector's intelligent sensors prevent false alarms: The Bosch Smart Home Motion Detector recognizes human movement based on body heat and size, thus differentiating between humans and pets. As a result, the alarm is only triggered when it is really necessary.
Triggers alarm signal
When you leave the house, you can activate your Motion Detector as part of the alarm system. If an unusual movement is detected while activated, the smart Motion Detector reacts in two ways: It immediately sends you a notification via the app. At the same time, it triggers an alarm signal, for example by the siren of your Smoke Detector.
Automatic light control
When you are at home, simply switch off the alarm function - and use the Motion Detector for automatic lighting control. In combination with your Philips Hue lamps and/or the Smart Plug, the sensores of the indoor Motion Detector automatically switch on the lights you have selected when there is movement.
Integrated pet immunity for your pet
Your pets can still move around the house without any problems despite your smart Motion Sensor Alarm. Simply activate the integrated pet immunity function. This ensures that the Bosch Smart Home Motion Detector also recognizes movements by pets up to approx. 25 kg and ignores them.
Box contents
1 motion detector
1 lithium-ion long-life battery
Fixing materials for screw and adhesive mounting
1 installation instructions
