The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time.
The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
A high power, 26dB gain signal booster, ideal for loop wired distribution systems. Designed for continuous operation and ideal for fringe reception areas.
- UHF input, very high gain 26dB and single output
- Suitable for TV, Video and Satellite
- Easy to install
- Delivers strong signals to one or more locations
- Supplied with fitted plug and 1m lead
