The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time.
The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
The Delta wall mount is a strong durable, easy to install wall mount for LCD / TFT monitors and LCD TVs. The Delta wall mount supports monitors up to 12 kgs and provides tilt, angle left to right and portrait to landscape movement. The two-piece design makes is extremely quick and simple to install with the minimum of tools. Finished in black. This LCD/TFT wall mount bracket offers up to 180 degrees rotation and 180 degrees of tilt and portrait to landscape movement. Its movement can also be locked off for touch screen stability. Supplied with both 75mm and 100mm VESA interfaces. Mounts to vertical surfaces.
