GL2070 LED featuring a dynamic ratio of 12M:1, 5ms response time and DVI connector, this 19.5"W LED monitor delivers every image detail with the best viewing quality.
With ENERGY STAR certification, this monitor ensures efficient power consumption, keeping your energy bills low and your environmental impact minimal.
Optimal viewing experience
The 19.5-inch LED-backlit LCD monitor, combined with a 1600 x 900 native resolution and a dynamic contrast ratio of 120,000:1, delivers sharp, vibrant images for an immersive viewing experience.
Eye comfort technology
Flicker-Free technology and Low Blue Light Mode reduce eye strain during long periods of use, making it an ideal choice for both work and leisure.
Versatile connectivity
Equipped with both DVI and VGA interfaces, this monitor offers flexible connection options to a wide range of devices.
BenQ GL2070 - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
DVI, VGA
Voltage
AC 120/230 V
Textured black, glossy black
46.2 cm x 18.9 cm x 38.6 cm
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
120
Backlight Technology
LED backlight
HDCP, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology
46.2 cm x 18.9 cm x 38.6 cm - with stand
DVI , VGA (HD-15)
Mechanical
VESA Mounting Interface
100 x 100 mm
Stand
1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 46.2 cm - depth: 18.9 cm - height: 38.6 cm - weight: 2.99 kg , Without stand - width: 46.2 cm - depth: 4.93 cm - height: 27.5 cm - weight: 2.41 kg
