The BL2700HT with flicker-free technology, low blue light and height adjustment stand enable you to find the best viewing angles and eyestrain from long hours of work. Never before had work been this stress-free!
VA panel comes with an ultra-wide viewing angle from left, right, above and below. Enjoy the flawless layering and precisely contrasted details in even the darkest images; viewing as you know it, has just gotten easier!
Rotate screen and desktop partition with display pilot software
Auto Pivot detects the rotation of the monitor and dynamically rotates displayed content automatically. All windows will be equally portioned and displayed on the screen when clicking on the Desktop Partition icon, which allows you to compare all design works with just, one simple click.
Slim bezel for dual monitor setup
The slim bezel makes the monitor look lighter and larger. In a multi-display setup with two or more units, thin bezels are less intrusive and effectively expand your work-space.
Ultra-flexible height adjustment system
An extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel - tailors to your unique build and viewing habits perfectly.
Flicker-free
The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue.
Low Blue Light mode
Every Monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique Low Blue Light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer.
Smart Reminder
The Smart Reminder gently reminds users to take a break in a predefined time interval. The breaks not only keep users' eyes comfortable and healthy, but also ensure desirable productivity.
Certified green
The BL2700HT is certified by internationally recognized green organizations to as a truly eco-friendly product.
BenQ BL2700HT - BL Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
37 W
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey), 12 ms (tr - tf)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Voltage
AC 90 - 264 V (50/60 Hz)
Black, non-glossy black
62.3 cm x 23 cm x 51.9 cm
6.3 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
55 kWh
Diagonal Size
27"
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Senseye 3 Technology, Low Blue Light Mode, Flicker Free technology, Ultra-Flexible Height Adjustment System (HAS), Smart Reminder
