Advanced performance for video streaming and online gaming
MultiBeam Technology
Belkin's exclusive MultiBeam antenna technology gives you maximum throughput while minimizing dead spots for optimized video streaming from multiple devices, virtually anywhere in your home.
Dual-Band Speed
Get the fastest dual-band speeds for video streaming and online gaming--up to 300Mbps (2.4GHz) + 300Mbps (5GHz).*
1 USB Port
Connect an external hard drive for easy sharing of photos and files, or connect a printer for wireless printing from any computer in your home.
Preset Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
Easy Setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're you out of the box and onto the Web.
+4 Apps
Enhance your online activities with Belkin's integrated apps: SELF-HEALING, VIDEO MOVER, PRINT ZONE and MEMORY SAFEā¢.
*The standard transmission rates--300Mbps (for 2.4GHz), 300Mbps (for 5GHz), 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower and may depend on the mix of wireless products used.
