Belkin's new WeMo system is home automation made easy. It's completely modular, so you can control as much or as little of your home as you like.
The Belkin WeMo Switch and WeMo Motion Kit gives you wireless control of your home appliances and electronics, turning devices of your choice on or off as soon as movement is detected. The sensor plugs into an outlet and detects motion up to 10 feet away. It then sends a wireless signal to the WeMo Switch to turn the connected device either on or off. Download the free WeMo app to any Apple device (iOS 5 or higher) to program a light to turn on when you walk into the house or a fan to turn off when you leave.
Key Features
Use motion to turn electronics on or off.
Operates over Wi-Fi and mobile internet, at home and away.
eMo works with your existing Wi-Fi router and any Apple iPod touch, Phone, iPad.
Put your electronic devices on a schedule.
Modular system. You can add additional WeMo Switches easily, any time.
Control as much or as little of your house as you want to.
6 `power cord and 10' motion sensitivity range allow for optimal placement of WeMo Motion sensor.
Plugs into any regular 120v wall outlet.
Intuitive, easy set up. Easy to use.
Free WeMo app.
WeMo Motion Turns Electronic Devices On/Off
The Belkin WeMo Switch and WeMo Motion Kit makes it easy to set schedules for home appliances and electronics and turn devices on and off remotely. The sensor detects movement up to 10 feet away and wirelessly signals the WeMo Switch to turn the connected device on or off, depending on your preference. The sensor's 6-foot cord lets you place it in the optimal position.
To get started, simply plug the sensor's A/C module into an outlet in your home and position the sensor. Next, plug the Belkin WeMo Switch into a separate outlet, and plug a device like a heater, fan, lamp, or stereo into the switch.
Next, download the free WeMo app from the Apple app store to your iPhone or iPad. Connect the sensor and switch to your home Wi-Fi network and follow the onscreen instructions to complete the installation.
Control Devices Using Your iPhone or iPad
You can use your iPhone or iPad to tell the sensor what to do, like have a heater turn off when you exit a room. You'll have wireless control wherever you go--the Belkin WeMo kit connects to mobile Internet networks so you can program the sensor to turn devices on or off even if you're away from home.
Set Schedules with WeMo App
The free Belkin WeMo app makes it easy to set schedules for appliances and electronics in your home. Use your iPhone or iPad to program a lamp to turn on or off at a certain time of day.
Add Multiple Switches and Motion Sensors for Increased Control
This Belkin WeMo bundle kit is completely modular, allowing you to control as much or as little of your house as you like. You can add an additional WeMo Switch to provide control of more areas of your home. Additionally, multiple switches can be linked to one sensor--turn on a light and heater or a set of lights at the same time with only one sensor.
Warranty and Compatibility Information
The Belkin WeMo Switch and WeMo Motion Kit is compatible with Apple devices (iOS 5 and higher) and your existing Wi-Fi router. It is backed by a one-year limited warranty.
WeMo Home Automation Switch + Motion Sensor bundle
WeMo Motion turns electronic devices on/off
The WeMo Switch and WeMo Motion Kit makes it easy to set schedules for home appliances and electronics and turn devices on and off remotely. The sensor detects movement up to 10 feet away and wirelessly signals the WeMo Switch to turn the connected device on or off, depending on your preference. The sensor's 6-foot cord lets you place it in the optimal position.
Add multiple switches and motion sensors for increased control
The WeMo kit is completely modular, allowing you to control as much or as little of your house as you like. You can add an additional WeMo Switch to provide control of more areas of your home. Additionally, multiple switches can be linked to one sensor - turn on a light and heater or a set of lights at the same time with only one sensor.
WeMo Switch + Motion - home automation kit - 802.11n
Home automation kit
Functions
Turn electronics on/off
Package Content
Motion sensor, smart plug
Wireless - 802.11n
Supported Host Device OS
iOS, Android
Home automation kit
Functions
Package Content
Wireless - IEEE 802.11n
Android 4.0 (Ice Cream Sandwich) or later, iOS 5.0 or later
