The high-performance Sport-Fit iPhone 6 Armband doesn't just protect your phone while you're exercising - it's also incredibly comfortable to wear. The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device.
The Sport-Fit Armband for iPhone 6 is made of a stretchy neoprene material that's breathable and hand-washable. It fits snug against your arm to give you full access to your screen without adding extra bulk.
The Sport-Fit iPhone Armband 6 is designed so that the home button and headphone port are fully accessible. You can quickly and easily operate your touchscreen and plug in your headphones while keeping your iPhone 6 inside your armband and on your arm.
