The Belkin N600 Dual-Band Wi-Fi Range Extender expands your wireless network, while its compact, elegant design complements your home decoration. With high performance speeds of up to 300 Mbps (2.4 GHz) + 300 Mbps (5 GHz) and external antennas for superior range, you'll have strong, reliable Wi-Fi throughout your home. Simple Start makes set up quick and easy on any smartphone, tablet or laptop - just plug the Belkin N600 Dual-Band Wi-Fi Range Extender right into the wall, access simple start and you're ready to go in minutes. Crossband technology increase speeds vs. normal range extenders by switching to the least congested band. Compatible with G and N technology devices, the N600 Dual Band Wi-Fi Router makes home networking a lot easier by keeping all your Wi-Fi devices connected.
