Better Wi-Fi performance to browse the Web wirelessly
MultiBeam Technology
Belkin's exclusive MultiBeam antenna technology gives you powerful signal strength and maximum coverage, while minimizing dead spots--so you can connect from virtually anywhere in your home.
Speed
The N300 provides wireless speeds of up to 300Mbps*--ideal for surfing, emailing and instant messaging.
Easy Setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're out of the box and onto the Web.
Preset Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
+1 App
Enhance your online activities with Belkin's integrated SELF-HEALING app.
*The standard transmission rates--300Mbps, 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower and may depend on the mix of wireless products used.
