Charge and sync your iPad, iPhone and iPod using just one cable. Simply plug the USB end directly into any USB port. Use the raised bump on 30-pin connector end to correctly orient the cable into your device, every time.
Belkin MIXIT ChargeSync Cable - charging / data cable - 2 m
Cable
Charging / data cable
Length
2 m
Blue
Connector
USB - male
Connector (Second End)
Apple Dock - male
Apple iPod (4G, 5G); iPod classic; iPod mini
Cable Type
Length
2 m
Blue
Connector
4 pin USB Type A - male
Apple Dock connector - male
Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini
