The Mini DisplayPort to HDTV display cable lets you stream high-quality A/V content from your laptop or tablet to your HDTV. Use it to watch movies, share photos, or expand your workstation with a mirrored desktop.
The cable's molded strain-relief design reduces strain on the cable to help prevent wear and tear. Its 6-foot length is ideal for connecting to hard-to-reach HDMI inputs on your HDTV.
Plug-and-Play wherever you go
Seamless Plug-and-Play capability makes this cable ideal for quick media sharing in any setting. The cable has the design that helps you easily identify the "right side up" insertion point.
