The car vent mount provides a safe and simple way to view navigation in the car. This cradle securely attaches your iPhone 6 Plus, iPhone 6, or other compatible smartphone to an air vent on your car's dash for convenient eye-level viewing - no suction cup or adhesive required.
The mount can be rotated 360 degrees so you can position your smartphone for viewing in either portrait or landscape mode. Portrait mode is ideal for charging, listening to music, and hands-free phone calls, while landscape view makes using your favorite navigation apps easier.
This versatile, low-profile mount clips easily to most vents, so you can use it in any vehicle. The adjustable brackets expand to fit most smartphones 3.3 inches wide, including the iPhone, Samsung Galaxy, and Nokia Lumia. It even works with a case on.
A cable holder on the back of the mount keeps your phone's connector tangle free so it stays neatly connected to your device. This also makes it easy to charge your smartphone while mounted using your car's power outlet (car charger sold separately).
