Designed using thinnest material that hugs the curves of your device, FreeStyle iPad Air cover is the perfect example of the old adage, "Less is More". With the same durable construction and thoughtful design details found in all iPad Air covers, the FreeStyle case for iPad takes sleek protection to a whole level.
The FreeStyle cover iPad Air case comes with an innovative QuickStand, a front cover that snaps to the back of the case. When opened, you can use it as a stand, and rotate your iPad Air to view content in either portrait or landscape mode. When you want to use the slim case on its own, just detach it and go.
