Car Charger 2.1 AMP For iPhone 5, iPad mini, iPad 4th gen
Small but Powerful
It's here -- the car charger designed exclusively for the iPhone 5. Get unlimited play and standby time with the low-profile design that sits flush in your dash.
Charge at the Speed of Lightning
Charge your iPhone 5, iPad mini or iPad with Retina Display (4th generation) at the fastest possible speed with the smaller, more durable Lightning connector. It's reversible, which makes plugging it in easier than ever.
Know You're Charging
Green indicator light easy to see your device is charging.
Small, Compact and Easy to Insert and Remove
Low profile design fits easily in your dash. Rubber grips allows you to insert and remove your lightning car charger with ease.
Features:
-Ultra-compact
-Plugs into any car power outlet
-2.1 Amp/10 Watts
-4' cable with reversible Lightning connector
COMPATIBILITY
iPad mini
iPhone 5
iPod nano 7th gen
iPod touch 5th gen
iPad 4th gen
