Fit for your life, Beats X earphones are the perfect wireless companion. Experience authentic, clear sound throughout your day with a long battery life. Their unique flex-form cable provides all-day comfort and easy pocket portability.
Incorporating the efficient Apple W1 chip brings seamless setup and switching for your Apple devices, up to 8 hours of battery life, and Fast Fuel technology for 2 hours of play with a 5-minute charge.
Wireless the way it should be
BeatsX works as hard as you do. Sleek, light, and compact, these earphones are your perfect wireless companion. They instantly set up - just power on and hold near your iPhone - then simultaneously connect to your Apple Watch, iPad, and Mac.
Stay connected, stay in the zone
RemoteTalk allows you to take calls with a built-in mic, play music, adjust volume, and activate Siri. The Apple W1 chip features Class 1 Bluetooth connectivity - the advanced classification for range and signal strength. With excellent performance, BeatsX seamlessly syncs to your devices, so you can easily move about, keep the music going, and stay productive throughout your day.
Sound that stays with you
BeatsX features authentic, clear sound with optimized noise isolation for an immersive listening experience. An innovative acoustic design delivers a clean treble response and distortion-free bass for the most natural tonality across a broad range of genres.
Fit for your life
Whether playing in your ears or hanging around your neck, BeatsX is incredibly sleek and comfortable for all-day wear. The unique Flex-Form cable provides a flexible fit, while a variety of eartip options offer personalized comfort. And when you're not wearing your earphones, magnetic earbuds keep them tangle-free, and they easily coil up for compact portability.
Beats X - earphones with mic
Earphones - Bluetooth - wireless
Compatibility
iPhone, iPad, iPod
Recommended Use
Portable electronics
Blue
Headphones Form Factor
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
Microphone
On-cable
Microphone Operation Mode
Mono
Controls
Volume, answer/end
1-year warranty
TV 4K, HD
Compatibility
iPhone, iPad, iPod
Blue
Recommended Use
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Noise Isolating
In-Cord Volume Control
Microphone
On-cable
Mono
Remote Control
Controls
Volume, answer/end
Carrying case, 4 ear tips, removable secure fit wingtips
