The decoupled 135 mm Shadow Wing's PWM fan ensures a perfect mix of cooling power and noise production. The waveshaped contour on the cooling fins minimizes noise and optimizes the air flow.
Four 8 mm heatpipes transport the heat along the shortest path to the optimal point within the cooling fins. The TopFlow cooler-layout enables ideal cooling not only for the CPU but also for surrounding components.
