Mounts projector only 115mm (4.5") from ceiling or 280mm (11") with supplied extension rod
+/-90° tilt adjustment, +/-90° roll adjustment and 360° swivel
Easy to adjust and fix projector in position
Steel safety wire for extra security
Maximum distance between any two fixing points on projector: 340mm (13.4")
Suitable for projectors with M2.5, M3, M4, M5 and M6 fixings
Simple installation with all mounting hardware included
Max weight
10kg (22lbs)
Tilt
+/-90°
Roll
+/-90°
Swivel
360°
