Back
Accessories
B-Tech Large Flat Screen Display Trolley with Glass Base for Screen
Quicklinx:
85FTWS00
Mfr#:
BT8505/B
Back
Marketing description is not available.
B-TECH BT8505 cart - for flat panel - graphite black
Cart
100 cm x 50 cm x 191 cm
Recommended Use
Flat panel
Recommended Display Size
30"-50"
VESA Mounting Interface
400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 200 mm, 300 x 300 mm
Max Load Weight
70 kg
Graphite black
100 cm
50 cm
191 cm
Graphite black
AV Furniture
Cart
Recommended Use
Flat panel
Cable Management
Integrated cable management
30"-50"
Max Load Weight
70 kg
Wheels
