The B-TECH System 2 BT7017 offers a range of mounting components, including an I-beam clamp and a tube mount adapter, providing flexibility for various installation environments.
Adjustable and secure
Featuring adjustable width and a lockable mechanism, this mounting component ensures a perfect fit and added security for your AV equipment, supporting up to 140 kg with ease.
B-TECH System 2 BT7017 mounting component - black
Mounting component
Mounting Components
I-beam clamp, tube mount adapter
Adjustable Width
8-25 cm
Adjustments
Tilt
Max Load Weight
140 kg
System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
Adjustable Width
8-25 cm
AV Furniture
Mounting component
Mounting Components
Cable Management
Cable Management System (CMS)
Adjustments
Tilt
Max Load Weight
140 kg
Adjustable width, lockable
B-TECH System 2 BT7850-025, BT7850-05, BT7850-10, BT7850-15, BT7850-20
