The BT7522 is designed for LCD VESA standard screens with a screen size up to 32", and weight up to 24Kg. The BT7522 has a tilt range of 30ยบ and mounts the screen only 55mm from the wall. A simple two piece installation process is all it takes to mount your screen to the wall.
Unique security screws, together with long hex key, are provided as standard to lock the screen to the bracket and help prevent theft. This bracket can be mounted on single wood studs or concrete/brick walls.
