AXIS Q3505-V is a high-performance, vandal-resistant fixed dome for high-security applications indoors. The camera is available with wide or telephoto lens. The camera delivers HDTV 1080p video at up to 60 frames per second, providing smooth video even when capturing fast movements.
The camera's Wide Dynamic Range (WDR) – Forensic Capture capability provides perfectly balanced video quality in scenes with strong variations in light, while the Lightfinder technology enables outstanding image usability in poor light. The camera can seamlessly transition between handling WDR and low-light conditions. AXIS Q3505-V also supports Axis’ Electronic Image Stabilization (EIS), which greatly improves video quality in situations where the camera is subject to vibration.
Furthermore, the camera supports barrel distortion correction and includes optical zoom that can be used when monitoring a scene. When using the optical zoom for monitoring, an operator can zoom in on an object, or the camera can zoom in automatically when the Gatekeeper functionality is applied.
