The palm-sized AXIS M3005-V Network Camera is an easy-to-install indoor fixed dome that supports HDTV 1080p and 2 MP resolution. It is ideal for retail stores, hotels, schools, banks and offices.
AXIS M3005-V is vandal- and dust-resistant, and designed for quick and flexible installation. With a 3-axis camera angle adjustment, the cameras can be mounted on walls or ceilings, and images can be easily leveled.
Convenient video management
AXIS M3005-V offers a convenient video management solution with its built-in micro-SDHC memory card slot for edge storage and support for software such as the complimentary AXIS Camera Companion. Video streams can be encoded in H.264 and Motion JPEG.
AXIS M3005-V Network Camera - network surveillance camera - dome
Network surveillance camera - fixed - dome - dustproof / vandal-proof
5.1 cm x 10 cm x 10 cm
200 g
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.7"
Minimum Illumination
1.5 lux F2.8
Focal Length
2.8 mm
Lens Mounting
M12 mount
Lens Iris
Fixed iris
Panning Range (degree)
175
Tilting Range (degree)
56
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control, e-mail alerts, image mirror, Wide Dynamic Range (WDR), AXIS Video Hosting System (AVHS), ONVIF support, Motion Detection Technology, Virtual Pan/Tilt/Zoom, digital PTZ function
C-Tick, VCCI Class B ITE, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, IEC 60950-1, EN 60950-1, KCC Class B, IP42, IEC 62262 IK08
