The AXIS 212 PTZ Network Camera for cost-efficient and reliable indoor surveillance, offers instant one-click pan/tilt/zoom control with digital PTZ. The built-in two-way audio support enables remote users to not only view, but also listen in on an area and communicate orders or requests to visitors or intruders.
The AXIS 212 PTZ incorporates a high-quality 3 Megapixel sensor and a wide-angle lens that allows the user to instantly zoom in on small or distant objects with exceptional clarity. This compact and discreet camera is ideal for monitoring shops, receptions, banks and other facilities where you need zoom in for detailed inspections.
With no moving parts exposed to regular wear and tear, the camera is ideal for automatic patrolling. It also provides effective protection against tampering as no parts can be forcibly moved.
Support for Power over Ethernet allows the camera to receive both data and power over a single Ethernet cable - which makes the installation easier and cheaper. If connected to a central Uninterruptible Power Supply (UPS), the camera can continue to operate even when there is a power failure.
Write a review for the Axis 212 PTZ. Pan/tilt/zoom camera here!
For the price of the camera, it is really good. The fish eye lens is exceptional in monitoring the area it is intended to. The built-in microphone is very, very small and you can still hear what people are saying to an extent, considering it's size. The outer case provides very good protection.
The negative points are that this particular model from the Axis series is very particular about the lighting conditions (it doesn't work as well in poor or excess light as the other cameras). There is also a backbox on an angle which allows the camera to be physically tilted, although you can't rotate the image to actually fit in with the position.
All in all, a good camera and we'll probably buy more of these, although maybe not as many due to some areas having undesirable light conditions.
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
