The F50 is many tools in one. A scanner, a web-video-digital camera, lined-graph-plain paper and with "best-in-class image clarity" you can see clearly with every single action.
Learning becomes wonderment when it's unfolding on the big screen and nothing puts on a show like the 5 megapixels of the F50 doc cam that's primed to show crisp text, bright images and vivid colors. The F50 is also engineered with a large imaging sensor to collect lots of light. More megapixels and more light mean better resolution and gorgeous detail for showcasing your classroom's best.
Zoom into it
Really get down to the nitty-gritty details of your experiment, math problem or poem. With 80x zoom, you can zero in on the smallest details and clearly see the big picture. So that tiny 1/8 or 1/16 of an inch on a ruler can be clearly seen by the student in the back of the class. A bonus is that when you are in digital zoom, you can move around the image while you are still zoomed in.
See micro worlds in action
With the F50's optional microscope adaptor, you can explore nature's tiniest communities in action. Simply fit the adaptor to any standard microscope eye-piece and you can now display small worlds on big screens.
Shed some light
Usually when the projector is on, the lights are off. Since the F50 is connected to a projector, it has built-in LED lights in the camera head to illuminate and display the objects underneath beautifully.
Make a point
Need to explain a tricky concept or emphasize a key point? By simply plugging in an USB mouse into the F50, you can easily add annotations, highlights, arrows and captions. You don't need a computer. Easy peasy.
AVer AVerVision F50 - digital document camera
Digital document camera
Audio
Yes: built-in microphone
38 cm x 20 cm x 54 cm
2.5 kg
Wired
Camera
Colour - 700 TVL - NTSC, PAL
Optical Zoom
2 x
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/2.5" - 5 MP
Focus Adjustment
Automatic, manual
USB 2.0, composite video, VGA, DVI
1 - USB cable - external , 1 - video / serial cable - external , 1 - VGA cable - external , 1 - video cable - external
Manual white balance, picture-in-picture capability, manual exposure, remote control, digital image rotation, digital image freeze, auto exposure control, adjustable self timer, image mirror, built-in LED lights, SDHC-card slot, negative conversion, image split, 1.25x AVERZOOM, auto white balance
Audio Support
Wired
38 cm
20 cm
54 cm
2.5 kg
Camera
Video Format
NTSC, PAL
Horizontal Resolution (TV Lines)
700
Max Digital Video Resolution
1920 x 1080
Digital Zoom
8
Frame Rate (max)
Still Image Capture Resolution
1920 x 1080
Image Sensor
5 MP CMOS 1/2.5"
Lens Construction
Optical Zoom
2 x
Focus Adjustment
Automatic, manual
Video
Composite video, VGA, DVI
Computer Interface
USB 2.0
1 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial / video - RS-232/composite video output , 1 x microphone - input - mini-phone 3.5 mm , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio - output - mini-phone 3.5 mm , 1 x USB 2.0 , 1 x display / video - DVI-Analogue/Digital output - 24+5 pin combined DVI
Carrying case, remote control, anti-glare sheet
1 x USB cable - external , 1 x video / serial cable - external , 1 x VGA cable - external , 1 x video cable - external
FCC, RoHS
Power adapter - external AC 120/230 V (50/60 Hz)
Software Included
Drivers & Utilities
Microsoft Windows XP SP2, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7
