15.6-inch portable USB-powered monitor with a single USB 3.0 cable for power and video signal transmission
The slim and thin profile helps you get things done more efficiently when you’re on the go
User-friendly design with embedded tripod socket on the rear and foldable sleeve for versatility.
Can automatically sense its orientation and switch the monitor between landscape and portrait modes.
