Quicklinx: | BJ0DWS00 |
Mfr#: | Z170-P |
CPU
LGA1151 socket for 6th Generation Intel® Core™ i7/ i5/ i3/Pentium®/Celeron® Processors
Supports 14nm CPU
Supports Intel® Turbo Boost Technology 2.0 - The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Intel® Z170 Express Chipset
4 x DIMM, max. 64GB, DDR4 3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz,non-ECC, un-buffered memory
Dual channel memory architecture
Supports Intel® Extreme Memory Profile (XMP)
(Refer to www.asus.com for the Memory QVL (Qualified Vendors List).)
Expansion Slots
1 x PCI Express 3.0/2.0 x16 slot (at x16 mode)
1 x PCI Express 3.0/2.0 x16 slot (max. at x4 mode, compatible with PCIe x1 and x4 devices)
2 x PCI Express 3.0/2.0 x1 slots
2 x PCI slots
Multi-GPU Support
Supports AMD® CrossFireX™ Technology
VGA
Integrated Graphics Processor- Intel® HD Graphics support
Multi-VGA output support: HDMI/DVI-D port
- Supports HDMI with max. resolution 4096 x 2160@24Hz / 2560 x 1600@60Hz
- Supports DVI-D with max. resolution of 1920 x 1200 @60Hz
Supports Intel® InTru™ 3D/Quick Sync Video/Clear Video HD Technology/Insider™
Maximum shared memory of 512MB
Storage
Intel® Z170 Express Chipset with RAID 0, 1, 5, 10 and Intel Rapid Storage Technology 14 support
- 1 x M.2 Socket 3 with M Key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
- 4 x SATA 6.0 Gb/s ports (gray)
- Supports Intel® Smart Response Technology (depending on the CPU installed)
