The reversible USB Type C port makes connecting devices much easier; and gives you fast USB 3.1 speeds. Its compact port design even helps preserve X540's thin dimensions.
Expansive audio
SonicMaster was developed with the clear goal of giving you great notebook audio. A professional codec ensures precise sound performance, while an optimized amplifier, larger speakers and resonance chambers deliver powerful audio output and deeper bass.
Crafted speaker design for greater sound
The X540 features round speakers, that maximize every cubic millimeter of available chassis space to give you better low frequency performance and reduced noise. The large chamber provides superior bass and excellent sound clarity.
Elegant finish
ASUS X540 has a solid and lightweight chassis - ideal to take with you when you're out and about. Its premium brushed finish turns heads and makes sure, that you stand out from the crowd.
ASUS Splendid technology
To ensure only amazing images, ASUS Splendid technology has color temperature correction to reproduce richer, deeper colors.
Protect your eyes with ASUS Eye Care
ASUS Eye Care mode effectively reduces blue light levels to make reading comfortable, and to protect you from potential eye fatigue and other ailments.
Ergonomic keyboard design
Typing is more comfortable with the X540's full-size, one-piece chiclet keyboard. An improved assembly provides minimal key float, so you get a more solid typing feel.
Stays cool
ASUS IceCool technology gives the X540 series a unique internal design, that addresses uncomfortable heating issues by preventing heat to build under the palm rest. This keeps the palm rest at a comfortable temperature. This internal layout places heat producing components away from you, and when combined with exceptional cooling from the heat pipes and vents, ensures you stay comfortable even after long hours of use.
