Stay connected wherever you go!
The WL-330NUL is the world's smallest pocket router at only 17.5g in weight and 6.5cm long. Whenever you're traveling or simply at a cafe, getting online becomes so easy with all your devices using this USB stick-sized router. Whether only Wi-Fi or wired LAN are available, it creates your own private network and allows speedy cross-device communication, making it extra-useful in staying connected anywhere.
Smallest pocket router - Flexible and easy to carry
The WL-330NUL measures 6.5cm in length and weighs 17.5g, making it about as easy to carry and handle as a USB stick. Just connect an Ethernet cable and instantly create a secure wireless network environment for all your devices. In addition, the WL-330NUL can also manage several network users at once, with different access privileges. It is a full-on communication enabler - not just a router.
Hot spot sharing - Share Wi-Fi accounts with multiple devices at no extra cost
The WL-330NUL features an easy to use and versatile hot spot mode. Wherever power and wireless connectivity are available, it allows sharing a single account on multiple devices, including notebooks, smartphones, tablets, and game consoles. Perfect for locations such as coffee shops and airports, hot spot mode makes sharing an internet account at no extra charge truly effortless.
USB Ethernet adapter - Your ultrabook improved with stable wired connections
As ultrabooks usually lack an RJ-45 wired LAN port and only support Wi-Fi, the WL-330NUL has been especially designed for business travelers and users of ultrabooks such as ZENBOOK, MacBook Air, and the new MacBook Pro. Simply connect a network cable to your ultrabook via USB port, and the WL-330NUL provides stable and reliable online access anywhere.
Wireless adapter - Power up connectivity with Wi-Fi access
The WL-330NUL is also the perfect backup should your integrated wireless hardware experience any issues. It allows you to stay connected uninterrupted. To get Wi-Fi access, simply plug it to your notebook via USB. This also makes the WL-330NUL perfect for desktops, which traditionally lack Wi-Fi capabilities and limit you to wired connections.
Several ways to power the WL-330NUL
1. From any USB port
2. Directly from the wall with the power adapter
3. Mobile power bank pairing
Smartest setup-free router
Access to every great feature is made truly effortless. Simply connect the WL-330NUL to an Ethernet cable and a USB power adapter, and it's ready to use setup-free. Then, quickly install the compact management utility for clear and helpful popup notices that help you manage guest access privileges with one click. Seasoned user or networking beginner, the WL-330NUL is your smartest mobile networking device in any location and situation.
Windows and Mac OS support
The WL-330NUL offers Windows and Mac OS compatibility. With its web-based interface, it affords easier user experiences and greater compatibility, covering a wide spectrum of devices such as ultrabooks, notebooks, tablets, and smartphones. The WL-330NUL is therefore an ideal choice for most users who need portable connectivity across multiple device types and locations.
