The ASUS VT168N touchscreen monitor combines 10-point multi-touch capability with amazing image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display - allowing up to 10 simultaneous touches to work smarter and more efficiently.
ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the best color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey.
VT168N has multiple video and peripheral connectors, including VGA and DVI-D, making it suitable for use anywhere, either in the home or at the office. VT168N features an elegant circular base with an ergonomically-designed tilting stand that lets you choose the ideal viewing position. The monitor is also VESA mount-compatible, making it easy to mount on a wall or monitor arm.
ASUS Eye Care monitor provides eye care features - Flicker free and Low Blue Light technology with 4 different levels that prevent your eyes from fatigue, strain that caused by screen flicker, hazard blue light and various light sources from office environment.
